96 Polaris magnum 425 bogs with air box on
Old May 26, 2017 | 10:37 PM
Tommyr1k's Avatar
Ok problem resolved. I removed the new (Chinese carb) carb and inspected the main jet, pilot air jet, and pilot fuel jet. The main jet was a 145 and not sure what the other jets were so I installed a 140 main jet, 40 pilot fuel jet, and a 160 pilot air jet which is what the clymer manual called for. Installed everything and it ran great. Thanks so much for your help.
Old May 27, 2017 | 05:02 AM
Glad you got it solved.That's why I've always been leery about Chinese knock off carbs. If anyone buys one they need to take them apart first and clean,blow out all passage ways and check jetting against the stock carb.
Old May 27, 2017 | 06:58 AM
Tommyr1k's Avatar
I agree!! Before I replaced the carb I actually ordered a new carb rebuild kit and after reading the fine print they changed the jetting size on that as well. Just for future reference is there a website I can go to to get the repair manual for other models?
Old May 27, 2017 | 07:18 AM
Here's a fuel section on the carbs that Polaris used on the Fuji engines.Covers the 2 stoke vm30,vm34 carbs,and the four stroke bst34 and bst40 carbs.https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA For cheap 5 buck service manual on Polaris and some of the other brands you can go here.http://www.brssm.com/
