2004 Polaris 330 Magnum 4x4
Old Jul 11, 2017 | 11:00 AM
stan5686's Avatar
Default 2004 Polaris 330 Magnum 4x4
Hello OPT, haven't been on here in a while. But I've came across a nice 2004 Polaris 330 Magnum 4x4. Price seems fair and condition is well above average for the age on machine. I'm not at all familiar with this model though. It looks to me like a regular Polaris, not a Chinese import. Are their anything on this model I should be cautious of, look at close, etc.? Your opinion as always is well respected! This site is lucky to have you!
Thanks
Old Jul 11, 2017 | 11:24 AM
Not a Chinese import.Does have the ecm module that can cause problems. Controls charging,has all the solid state circuit breakers inside,plus controls several other functions. Not a big enough problem not to buy a clean Magnum though. Also the rear prop shaft(#16) has a grease zerk that's hard to see and many people over look them. If not kept greased the prop shaft spines can strip out. Lot of work to change one out if it does.Zerk is visible through hole in the box frame. Other than that they were a good utility/trail machine. I'd be sure to get the service manual and go over it.2004 Polaris Magnum 330 Service Manual PDF Download
Attached Thumbnails 2004 Polaris 330 Magnum 4x4-d6179d56e87598bb1be7e6d65c2f5b40643b6634.png
