Will a xpedition 425 shift drum fit a xpedition 325
Old Sep 2, 2017 | 04:59 PM
donn92's Avatar
Default Will a xpedition 425 shift drum fit a xpedition 325
I own a 2001 xpedition 325 that needs a shift drum and found a few used drums for a 425 my question is will then work in the 325
Old Sep 2, 2017 | 05:17 PM
Look the same but show different part numbers.Couldn't say yes or no on this. Drum is listed listed under clutch. If you ever want to see if parts interchange with other models go to Browse Find the part number for your model, go to the right and click under usage. Tells what models use the same part number.
Usage : 3086938 Shift Drum Assembly (325)
Year Product Model Assembly
2002 ATV XPEDITION 325 CLUTCH - A02CK32AA (4970287028D06)
2001 ATV XPEDITION 325 CLUTCH - A01CK32AA (4964086408D005)
2000 ATV XPEDITION 325 CLUTCH - A00CK32AA (4954895489D009)
Usage : 3086366 Shift Drum Assembly(425)
2002 ATV XPEDITION 425 CLUTCH - A02CK42AA/AB (4970327032D09)
2001 ATV XPEDITION 425 CLUTCH - A01CK42AA (4964136413D008)
2000 ATV XPEDITION 425 CLUTCH - A00CK42AA (4949304930D010)
Old Sep 2, 2017 | 06:12 PM
donn92's Avatar
Default Will a shift drum from a xpedition 425 fit a 325
Thanks for the help do you know of anyway to find out if it is the same part
Old Sep 2, 2017 | 06:23 PM
Not unless you held them side by side and also examined the shift fork groove pattern against each other. I would like to say it would work,but can't. Even the stripped down drum and not the assembly have different part numbers on each one.
