Fox shocks 2.0 for rzr xp Fully adjustable & position sensitive
NIB and never installed. I went in another direction and need to get rid of these. They are a big improvement of the factory shocks with a lot of tunability. these set me back over $2,400... they are yours for $1700 pm for payment options
for more info
FOX RACING SHOX :: SIDEXSIDE : SHOCKS : 2.0 POSITION-SENSITIVE COIL-OVER
For 2010, the all-new Position-Sensitive 2.0 (available with DSC) gives you position-sensitive damping for the optimal compression damping at each phase of the stroke, and its wide range Dual Speed Compression adjustability allows a set-up that?s perfect for driver style and course condition. The internal bottom-out cup provides additional damping at the very bottom of the stroke to give you the ability to push your vehicle harder for longer with improved driver confidence. Less compression damping at ride-height gives improved comfort and traction while huge damping in the end-zone helps to flatten out the biggest bumps.
The FOX 2.0 coil-over piggyback shock, now available with dual speed compression adjust and rebound adjust, will let you fine-tune your ride and handling to suit personal preference and terrain. The large diameter shock body and piggyback reservoir help to dissipate heat and keep things running cool. No other shock on the market packs all of these features at this price!
for more info
WesTech
11
Aug 11, 2015 07:55 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
