2010 800 rzr lean fuel symptoms
Old 12-13-2017, 02:31 PM
jstjoehere's Avatar
Default 2010 800 rzr lean fuel symptoms
This unit idles however when throttled it starts popping back through the intake and missing. Fuel pressure is 42 psi constantly. I replaced both injectors when i rebuilt the top end. Both injectors ohm out fine and when disconnected at idle i can definitely hear them cut out. I have inspected all sensor connections and checked wiring through the harness. No check engine light and no codes. Ive also checked for intake and throttle body leaks. Exhaust doesnt seem to be restricted. Im waiting for my otb scanner to arrive so i can read the ecu to see whats going on. Im is there anyway to ohm the tps and tbap sensors in order to know ifbthey are faulty? The more i read the manual and think on this the more i lean to a faulty ecu.
Old 12-13-2017, 02:52 PM
Look at your other post. Usually not sensor related but the wiring and connector leading to the sensors.
jstjoehere
13
07-23-2018 09:00 AM
Ipmcelroy
02-17-2016 05:47 PM
chadster1
09-08-2011 04:10 AM
rivermud
09-10-2004 10:36 AM
Quick Reply: 2010 800 rzr lean fuel symptoms
