400 Sport Electrical Failure
Old May 15, 2003 | 04:53 PM
LuminiTe's Avatar
Default 400 Sport Electrical Failure
I have a 94' sport 400 (thinks its a 94) and none of the electrical works... elect start, reverse override, headlights, nothing.... BUT the indicator lights do work while machine is running (must pull start) I replaced the battery and same problems.... I bought the machine wrecked and fixed everything else but am unable to figure out the electrical. ANy suggestions? and i missing a fuse or breaker or something of that sort?
Also i am afraid it may overheat because it is liquid cooled and i havnt noticed the fan running yet either....
Please help....
Old May 15, 2003 | 05:37 PM
lovemud's Avatar
It might help to buy a shop manual from polaris, the schematic diagram would be included. you'll have to trace these systems back to a common point of failure. I'll put money on a loose or corroded connection someplace, most likely on the control module.
Old May 15, 2003 | 05:49 PM
LuminiTe's Avatar
Thanks for the quick response.... As soon as i can get to town i was going to pick up a manual.... ( i am almost 100 miles from closest dealer)
Will look into a loose or corroded wire somwhere thanks
Old May 15, 2003 | 06:11 PM
NCScrambler's Avatar
You will also have one or two circuit breakers, they are in little plastic pouches and supposed to be sealed, you can get replacements at anm auto store fairly cheap, you just have to get the right size and waterproof them.
Old May 15, 2003 | 06:18 PM
250EXcited's Avatar
Had the same problem with my wife's Scrambler last week. Turns out the neg. battery cable had come loose from the connector where it connects to the motor.
Old May 15, 2003 | 06:54 PM
ftwflh's Avatar
Check your grounds and replace the bulbs that dont work.Then check the starter relay.If I was betting I would just change the relay anyway.
Old Oct 18, 2004 | 02:20 PM
Cajunhunter41's Avatar
Hi did you find the problem yet? I have a 99 500 sportsman. Turn the key on nothing. you can pull start it and then the lights flicker. pulled the battery cleaned and charged. it has a bad miss in reverse unless the override is pushed. and kills alot. Let me know what you find. Thanks
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Sep 30, 2015 01:37 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
cboler9
Sep 24, 2015 08:35 PM
