TINY TACH
Old May 15, 2003 | 11:12 PM
Jwb's Avatar
Jwb
Default TINY TACH
I just installed a tiny tach and it is reading to many R's like 8200 at half throtle any advise???????
Old May 16, 2003 | 04:16 AM
ProXPredator's Avatar
Default TINY TACH
Need more info - what did you install it on, 4-stroke, 2-stroke, etc
Old May 16, 2003 | 11:06 AM
Jwb's Avatar
Jwb
Default TINY TACH
installed on my 400 scrammy and at half throtle it reads 8 grand
Old May 16, 2003 | 11:29 AM
modquad's Avatar
Default TINY TACH
You might want to check to see if the tach has an adjustment for PPR ( pulses per revolution). I know the Predator is 6, but don't remember what the Sport/Scramblers are. Maybe someone with that will chime in.
Old May 16, 2003 | 12:39 PM
NCScrambler's Avatar
Default TINY TACH
I think it is 4 for the Scrammy. It is with my tach anyway. I think there are different Tiny Tachs, some of them work with Polaris, some don't.
Old May 16, 2003 | 02:40 PM
Default TINY TACH
Arn't some also based for 2-stroke and some for 4-stroke?
Old May 17, 2003 | 02:46 AM
firemedic5586's Avatar
Default TINY TACH
Just for grins, try moving the pic up wire down more towards the plug. I had the same problem with my 700. When I moved the wire farther away from the coil it read fine.
Old May 17, 2003 | 01:54 PM
NovaKaw650's Avatar
Default TINY TACH
See what model tiny tach you have - I think 2C is what works on the Polaris.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
