Battery or charging system?????
I would change out that battery. You could do a couple of things first. First, disconnect the ground side battery cable in hook a non-powered test light...if it lights brightly, you've got some sort of current draw. Also, you can charge up that battery, leave it disconnected overnight, and use a volt meter to see if it retains it's charge. Walmart sell the replacements cheap. Are you using a winch, or aux. lights?
If the battery seems OK, the first place to look would be the voltage regulator. It is the little box with wires coming out of it (that sometimes pull loose) on the front of your quad. Just be sure all the wires are attatched securely.
Farmr
Farmr
cody500ho
14
Aug 14, 2015 05:03 PM
