Thank You Polaris "Predator Test Crew"
#21
#22
Here is a link to some more info on the 2004 Predator
Not sure if its true or not
There are more changes than that. They are welding the top motor mount instead of a bolt on to stop the stressing and cracking of the frames that some are experiencing. They also are going with beefier ball joints with harder internal components. The tierods are a bigger diameter which means the 2003 quads can't use the new ball joints unless you go with the increased diameter steering components of the 2004 quads. There are a few other changes, but small. So you are right, they are close to the same as the 2003's.
#23
bzdok1234
30
02-23-2016 01:55 PM
