39 pwk air screw?
i just can't seem to get mine adjusted right after removing my injection. i was running a 172 now im using a 175 it was a little lean so i adjusted it out some and it got way too rich now i cant find the right spot. Do you know how many turns out the screw comes from hpd? thanks for replying so fast on the last one
keep in minsd that the pwk 39 is a FUEL screw so a lot more sensitive than a air screw,it is effective 1/2 turn out to 2 turn out only,
it is counter clockwise to lean,if you got a rich pilot jet you'll
almost run the fuel screw 1 1/2 turn out.
Oct 10, 2015 10:20 AM
