Aaen spring
Old Jul 24, 2003 | 08:02 PM
mudslinger250's Avatar
Default Aaen spring
I am planning on getting a new primary spring for my trailblazer from aaen and was wanting to know what color to get. I also want to re-jet it. What size jets do i need to get? Thanks
Old Jul 24, 2003 | 08:09 PM
2manytoys's Avatar
Default Aaen spring
If you want better take off without the rpm's going through the roof before it takes off then something equal to a Polaris white or EPI red would be good. Also you really cant rejet much higher without a pipe. Stock is 130 you can safely go to a 140-145 main with a K&N filter. This will help with performance. You really wont get much more gain without a pipe. The pipe will give you a huge gain.
Old Jul 24, 2003 | 11:20 PM
Default Aaen spring
I have a DG Type II exhaust system. Im sorry I forgot to put that on thier whould this change what to get? I ordered a red EPI from dennis kirk and the spring was almost twice as long as the stock spring and was way to much engagment. So do you know of any other company or color?
Old Jul 25, 2003 | 07:55 AM
NCScrambler's Avatar
Default Aaen spring
Olav Aaen is the main man for clutching. He can set you up with whatever you want to get out of your machine. Your best bet is to call Aaen and tell them what you are after and they will hook you up.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
mitchxc700
Aug 10, 2015 09:26 PM
Mphillips
Jul 2, 2015 07:20 PM
