Polaris tranny question
Old Jul 29, 2003 | 03:58 PM
hondabigred's Avatar
Default Polaris tranny question
My Trailboss grinds a little when trying to take it out of neutral. If you start it in gear it works fine. The linkage is bent a little. Does anyone think it could be the gearbox if it still works fine. I don't wan't to buy new linkage if the gearbox is bad.
Old Jul 29, 2003 | 04:18 PM
BigBadScrambler's Avatar
It could be the linkage. Or it could be that your idle is to high. Or even that you clutches need to be aligned and your belt is engageing a little. Try applying the brake before you shift and see if it still does it.
Old Jul 29, 2003 | 09:44 PM
POLARISFREAK's Avatar
Check the tie rod looking end that connects at the transmission, I had a guy bring me his to work on becuase the local polaris dealership told him it needed a new transmission and all that was wrong with it was the tie rod looking joint at the trans.
Old Jul 29, 2003 | 11:51 PM
fastpred500's Avatar
Are you reving it then shifting?(Like is it still in the upper rpms when you push the shifter foward.)
Old Jul 30, 2003 | 12:21 AM
It did turn out to be the tie rod looking end. Thanks Alot!!!!!
Old Jul 30, 2003 | 12:24 AM
modquad's Avatar
Also, with the great tips the others already gave, don't forget to give the shift linkage a shot of lube periodically. [img]i/expressions/face-icon-small-happy.gif[/img]
toonces
Oct 16, 2019 12:11 PM
Gtsordo
Jul 13, 2015 10:38 PM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
