whats happening
Old Aug 5, 2003 | 09:57 AM
markbanger's Avatar
Default whats happening
Whenever i ride my bike like for 30 min+ i quits on me and I have to start it back up. I don't think its over heating because my fan dosn't come on ????
Old Aug 5, 2003 | 10:05 AM
03PolarisPredator's Avatar
maybe your red light doesn't work and you don't know it, but it is overheating? Did the fan used to run fairly often? maybe the fan is not working, therefore the engine gets hot, and the motor shuts down when it senses it is too hot, but the red light did not come on because it is not working? Does the red light come on before you start the quad, like when you turn the key on?
Old Aug 5, 2003 | 10:57 AM
markbanger's Avatar
I think the red light is broken the fan came on 3 times so far in 6 months?
Old Aug 5, 2003 | 11:04 AM
USMCQuader's Avatar
THe fan on our trailboss runs quite a bit. 3 times in 6 months seems a little low unless you are always driving fast or in cold weather.
Old Aug 5, 2003 | 12:21 PM
dodgepower's Avatar
kinda same thing with mine .....its at the shop as we speak after about an hour it wont idle and will die when going down a hill....will let ya know what i find out
Old Aug 5, 2003 | 12:22 PM
dodgepower's Avatar
Hey marine.....squid here......hey do you like that hpd exhaust and clutch together.....thinkin about switching the aeen and white bros i got to a matching set like that
Old Aug 5, 2003 | 12:25 PM
USMCQuader's Avatar
It gave it some good power, but nothing insane. Defeinately more low end, and a modest mid, but I would say that top end is the same. For the money, work, and trouble, you are probably better staying where you are.
Old Aug 5, 2003 | 12:55 PM
TahoeRider's Avatar
I have an '03 Trail Boss and I have never seen a red light come on when I start my machine...My fan does work though.
Am I missing something..You guy with Trail Bosses, do you have a red light that comes on when starting?
Old Aug 5, 2003 | 12:57 PM
dodgepower's Avatar
Aight thats marine....appreciate it....
Old Aug 5, 2003 | 02:25 PM
Pennyless's Avatar
On my Xplorer I installed a temp guage ( see pics ) and hooked the red light up to my fan so when the fan is running the light is on. I did this because concern that the fan hardly ever ran. Now whenever the fan runs the light is on. After doing this I discovered that 95% of the time my ATV runs below 120 degrees. At around 130 is when the fan comes on. I also installed a switch to manually turn the fan on if I want to. Just some info you might want to think about.
