Predator starting problem
Old Aug 16, 2003 | 08:00 PM
prang11's Avatar
Default Predator starting problem
One of our predators is not able to start in any gear but neutral. When it dies you cant just pull teh clutch in and start right back up, instead you need to find neutral then start it. Our other predator is able to start in any gear. Anyone had this problem? Maybe i have a disconnected wire or something? Anyhelp would be great.
Old Aug 17, 2003 | 12:59 AM
jsyi's Avatar
The only reason this would happen is if the "switch" thing that plugs into the clutch perch got messed up. you should check that the connection is good. When I switched my levers and perches I took all that crap off. I didnt realize what it was for till the first time I stalled in the dunes on my dune trip which made it a real pain in the *** the rest of the trip[img]i/expressions/face-icon-small-sad.gif[/img] Check to see that its still plugged in and that the little thing looks to be in okay shape. I think its supposed to be a little rev limiter thing of some sort. Im not too sure though..
Old Aug 17, 2003 | 03:56 PM
prang11's Avatar
Went out and tore that apart right after i posted this and cleaned it all up. Now just need to put it all back together (the whole bike is torn down) and start it up to see if it works. Hopefully that was the problem so i dont have to take it to the dealership. Thanks
Old Aug 17, 2003 | 08:23 PM
jsyi's Avatar
no prob
Predator_500
Jun 13, 2015 03:01 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
Falcon150
May 25, 2015 05:36 AM
