wiring question
Old Aug 17, 2003 | 08:30 PM
scrambler123's Avatar
Default wiring question
which color headlight wire is the low and high beam?
Old Aug 17, 2003 | 08:52 PM
scrambler420's Avatar
im not sure which color is which,but im sure someone on here will know..you can always put a test light to the wires that will tell ya..
Old Aug 17, 2003 | 08:58 PM
ftwflh's Avatar
There is a schematic in the back of your owners manual if you dont have that I really recomend you by a SERVICE MANUAL you cant own a Polaris without one.
Old Aug 18, 2003 | 04:44 PM
I dont have a service manual does anyone know what color the low beam is?
Old Aug 18, 2003 | 05:47 PM
RookWV's Avatar
I offered an answer in your last posting concerning this....
Last post on wiring
Old Aug 18, 2003 | 06:56 PM
so the yellow and brown wires are high beam? i thought the brown was the ground
Old Aug 18, 2003 | 09:31 PM
vampireforeman's Avatar
dude u really dont understand how electricity works do you brown apparently is ground, one of the other wires , the one with the higher voltage would be high beam; brown is also ground on low beam side ..the lower voltage side...do you own a multimeter?
Old Aug 18, 2003 | 09:33 PM
test light probally not acuurat enuff to tell high from low it would light up on both sides with very little difference in brightness
Old Aug 18, 2003 | 09:41 PM
ftwflh's Avatar
Your hi and lo are on seperate circuts
Old Aug 18, 2003 | 09:46 PM
yea and they share a common ground one ground for hi and lo, 2 hot wires(1 hi 1 lo) with varying voltages
