what two stroke oil for scrambler
Old Aug 20, 2003 | 12:04 PM
95sport400's Avatar
Default what two stroke oil for scrambler
You can buy Amsoil here: Amsoil or locate a dealer near you, or become a dealer or preferred customer yourself. If you've got buildup with a synthetic, you're burning way to much oil. There is NO - I repeat NO- dino sludge oil made that is even close to the synthetics. Of course they work, they worked for decades. Synthetic just works BETTER.
Old Aug 20, 2003 | 02:48 PM
scramblered's Avatar
you can only say it burn clean if you remove the head and check the inside cylinder walls and pistons wash,the port cylinders too,then you'll
see some MAJOR build-up at the exhaust port,i've tried ALL klotz oil
and amsoil stuff at 50-1 ratio and always run too damn pig...
simply that engine is not a high revving motor with no power valve,
so it only need standard oil...
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
