help on 2004 scrambler in mud
#21
A scrambler in mud or water is allways a good time but keep in mind that you may not have the best rubber for the mud but for the turf. Lots of power is there but tires are a part of the outcome. Don't go bigger but deeper tread or paddle helps gobs in the pudding. Also, I want to alert you polaris owners of a potential problem with the inside seal on the PVT, behind the drive clutch. The plastic box twists, more under hard riding, and causes the seal to contact the spinning clutch.....chew...chew...out comes the puller and fix or water will get in...I'm told that the new polaris has a bracket in place to help reduce the twist but some twist is a must or something else gives.
2001 scrambler 500, yellow with checkered flag decals and winch up front....used once!!!!!
2001 scrambler 50 for my boy...
2003 raptor 80 for my girl...
wife will be getting 2004 400 sportsman next year...if she's good.....
exmotocrosser
09-13-2019 06:12 AM
Sw00p
09-24-2015 02:50 PM
