what about a sp700 for $4500...........Help!!!!!!
Old Sep 6, 2003 | 09:43 AM
Farmr123's Avatar
Default what about a sp700 for $4500...........Help!!!!!!
The 700s have no hub fluid, the locking mechanism is all in the front differential now. However, be sure to use HUB FLUID in the front diferential, and NOT the gearcase oil like you would on the 400-500.
Old Sep 6, 2003 | 11:43 AM
Northstar2's Avatar
Holy smoking deals, Batman! I wish I could have got a 700 for that kind of money. I bent over and paid $7500 for mine new. Now I always see where people get them cheaper than most new SP400s cost around here. Why do you suppose the midwest sells them cheaper than New England??
Any wya, congratulations! The water pump cover was a problem on the early 02s, just watch for coolant seepage on the right side of motor. I guess a lot of them have frames that crack, but I'm not sure where. So, I'd clean it real good and look it over. Even if you have to fix a few things, you got a good deal.
Old Sep 7, 2003 | 01:33 AM
curlytop's Avatar
thanks for everything, but I still have a few more questions.
What would cause play in the steering. It's not much but would like to know.
What would cause the speedomiter not to work. (How much would one cost if I have to buy a new one)
Thats all ,for now anyways
Old Sep 7, 2003 | 10:58 PM
upnort's Avatar
There is some play in steering. Most likely place for wear would be ball joints, grab each rod to each and check for movement. As for the speedometer I would lift the back so the rear wheels could spin and remove the cable from the back of the speedo to see if is before speedo or the speedo. They run a couple hundred.
Old Sep 8, 2003 | 12:55 AM
  #15
2004ds650's Avatar
hey brush crusher theres no need to be cocky. i mean after all ur just as dumb for buying a pooplaris. after a few years u could call urself bank crusher with all the money u'll be spending on it
Old Sep 8, 2003 | 01:23 AM
  #16
BigBadScrambler's Avatar
HA!!! you crack me up DS wanna. Why don't you go ride your PW50 and stop trying to start crap. Comprenda??
Old Sep 8, 2003 | 08:31 AM
  #17
Brushcrusher's Avatar
Bankcrusher....pretty funny.... really.. made me laugh. Wasn't trying to be cocky ,just thought curly was pulling my leg.
Old Sep 8, 2003 | 09:39 AM
  #18
Farmr123's Avatar
The new speedos are electronic. There is a speed sensor by the right wheel. It reads speed by 'counting' holes in the brake disk as they go by. Be sure it is in alignment with the disk, and close to, but not touching it.
If the backlight for the speedo doesn't come on, it is not getting power. Look for a bad wire, bad ignition switch, or bad speedo unit.
Farmr
Old Sep 8, 2003 | 10:55 AM
  #19
V8s10's Avatar
Well, you know it cost a little more to go first class. Good thing most of us Polaris owners are rich.
Old Sep 8, 2003 | 06:35 PM
  #20
curlytop's Avatar
I was just pulling your leg man.
