Help this is bad!!!!! Scrambler 500
Well i got my hpd pipe and clutch kit all went in well then I was rideing it runs very good but my friend said look at your header it was glowing red hot i put the 160 jet and did the 3 turns on the pilot screw i dont no what elce to do. also hpd said to put the rear clutch 2-3 is that a good set up. Thanks
How long did it take before the head pipe started glowing? Was it dark out? I have heard of some machines doing that. To tell you the truth, I have never looked at mine when it was that hot. I have heard of them glowing on other machines, like the Pred and SP700. I am not sure on the secondary spring setting. I THINK mine is at 2-2, but Im not positive. USMSQuader had that problem with the instrcutions saying one setting an the actual setting was different. Hopeful he will though his insight in on this one
OK WELL TOMORROW I WILL TAKE IT OUT AGAIN AND SEE WHAT HAPPENS. CAUSE THE TEMP LIGHT DID NOT COME ON SO IT COULD HAVE NOT BEEN TO HOT I GUESS ITS OK WELL I WILL KEEP YOU INFORMED ON WHAT HAPPENS ALSO ANYONE KNOW WHATS THE BEST REAR CLUTCH SPRING SETTING CAUSE MY QUAD SEEMS SLOWER TO ME??
OK AT FIRST I PUT IT AT 2-3 IT RAN FINE BUT TOPED OUT FAST SO I LOOKED OVER THE THREAD I NOW HAVE IT AT 2-2 AND IT RUNS EVEN BETTER DOES NOT TOP OUT FAST IT KEEPS GAINING SPEED AND THE RPMS STAY NOT TO LOW AND NOT TO HIGH JUST RIGHT. AS FOR THE GLOWING OF THE HEAD PIPE MY CARB WAS NOT PUSHED IN FAR ENOUGH AND WAS SUCKING AIR. NOW ITS GREAT HPD RULES!!!
exmotocrosser
Sep 13, 2019 06:12 AM
