A Few Predator Bolt Sizes
Old Sep 30, 2003 | 04:53 PM
Hozed's Avatar
Default A Few Predator Bolt Sizes
ya i wanted to know how much wieght was lost too.
Old Sep 30, 2003 | 05:23 PM
modquad's Avatar
Generally speaking, a ti bolt (smaller variety) will cut the weight in half, as copared to a steel bolt of equald size. Now when you get into larger fasteners, engine mounts, wheel studs, etc, the weight savings can be quite a bit more. I haven't had a chance to drop the machine on a truely accurate scale system lately. It's the old drag racer in me that seeks out the ounce in sixteen places to make that pound. You also gain strength, and it never corrodes. If you take one corner of a machine ( wheel studs, brake caliper mounts, and a few others, like shock and a-arm mounts), and over time change out those fasteners, you should easily be able to surpass the pound mark. Now match that up with other misc fasteners around the quad, and you could easily approach the 8+ lbs mark. Eventually, match that up with chromoly a-arms, swingarm, steering stem, and rear subframe, touche' it'll be a light one. [img]i/expressions/face-icon-small-happy.gif[/img] Like I've always stated, do it over a period of time, then it's cost won't seem so bad.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
akguy31
Aug 31, 2019 04:34 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
