Plastic Trim from a Scrambler
Old Sep 24, 2003 | 09:25 AM
RookWV's Avatar
Default Plastic Trim from a Scrambler
What about a high pressure power washer? I've got a 2550psi power washer.......
Old Sep 24, 2003 | 12:34 PM
BigBadScrambler's Avatar
You can give it a try. But that powdercoat is some TUFF stuff. I could have MAYBE finished ny had sanding it but gave up and painted it chrome. Still turned out good
Old Sep 24, 2003 | 01:44 PM
dodgepower's Avatar
Hey CED what did you just soak in in paint remover or rub it off with a rag or something? Also did what kind of polish did you use? Can I use like this Blue Magic stuff I got for my wheels? Hey Rook let me know if that works cause Ill just send it to you[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 24, 2003 | 01:53 PM
CED's Avatar
CED
The stuff i used to remove the paint is some real bad stuff.It is actually a gel,you just let it sit a while and the paint starts to bubble.Then i just pressure washed it.It is the same stuff they use to remove graffiti.I used some aluminum polish that i get locally called way-to easy.Any aluminum polish will work.I took some new pic's last night,just waiting for them to come up.You should be able to find the paint remover at any hardware store.Just be careful.
Old Sep 24, 2003 | 05:53 PM
  #15
fishslab's Avatar
I checked out this link from another thread. There are some hot quads here.AZ bad boyz
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
