BigBadScrambler
Old Oct 1, 2003 | 08:48 PM
viperstripe's Avatar
Default BigBadScrambler
you have a nice scrambler how much were those lights and were did you get them/ and was it hard to put on that trail tech speedo how does it tell speed thru the tranny? thanx for info
Old Oct 1, 2003 | 10:04 PM
RookWV's Avatar
I'm not BBS but....he got the lights at an auto parts store I can't think of the name, we don't have them around here but he said they were similar to any aftermarket lights you find in the automotive dept....about$30-40 I think is what he paid....
The trail tech is simple.....a cable runs down from the handlebars to a sensor mounted on the strut....you then glue a magnet to the brake rotor and calibrate it by wheel size. The only scary part is drilling the hole to mount the sensor.
Old Oct 1, 2003 | 11:07 PM
Bubba297's Avatar
viperstripe, I like your icon.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
Old Oct 1, 2003 | 11:32 PM
thanxs for the info rook
yea i found the icon on fome ford site and i was like damb that would be nice for the forums
Old Oct 2, 2003 | 12:32 AM
BigBadScrambler's Avatar
Thanks for the compliment Viperstripe. I got the lights from Meijers (our local "superstore"). You should be able to find something similar at Walmart or any auto parts store. They are the Pilot Cyber White 55wt Simulated H.I.D. lights. They cost $40. They have that blue tinted glass lense that looks way better than the stock plastic lense. They are about the same size as the stock ones and have the same type of mounting bracket. I did have bore out the mounting bracket hole a little and I had to grind a little of the plastic housing at the top to get it to fit right to the headlight gaurd. Not that hard though. I used some connectors and connected the wiring to the existing headlight wiring so that I could use the existing headlight switch. I had to solder the high and low beam wires together because the lights are only on and off, no high or low. This means that they will be on whether I have it on high or low. If you need me to I can go more indepth with the wiring. It took less than an hour to do the whole thing. I think that Rook pretty much nailed the whole Trailtech setup. Very easy. I used JBWeld to attach the magnet though. Both the lights and Trailtech are things that I would highly recommend.
Old Oct 2, 2003 | 11:05 PM
trailrider500's Avatar
Big bad were did u get your bars i have been looking every were for some renthal bars. The only ones I have found are not for the scrammy.
Old Oct 2, 2003 | 11:53 PM
I got mine through Rocky MT ATV. Thay are the Banshee bend bars
Old Oct 2, 2003 | 11:57 PM
Ok i see there for a banshee. thanks big bad
Old Oct 3, 2003 | 12:02 AM
no problemo
JEFF10049
Nov 6, 2005 12:06 PM
Bradracer18
Oct 20, 2005 11:22 PM
BigBadScrambler
Jun 9, 2004 07:20 PM
4464
Jan 18, 2004 10:56 PM
scrambo
Nov 21, 2003 06:05 PM
