cv boot??
Old Oct 4, 2003 | 07:09 PM
twoee96's Avatar
Default replaceing rear cv boot??
I have a tear in my rear cv boot. Should I fix it my self or take it in to be done? Can anyone give me a a quick lesson on how to do it?
Thanks!
Twoee96
Old Oct 5, 2003 | 08:55 PM
upnort's Avatar
Default cv boot??
Had mine done cost about 80$.
Old Oct 6, 2003 | 02:07 AM
Traildog's Avatar
Default cv boot??
It is not difficult to change a cv boot you can do it using normal tools and a little skill.
Suspend your quad and remove the wheel.
Remove the 2 rings that hold the boot on (if you don't have the proper pliers you can use needle nose pliers.
Remove the cotter pin and the large castle nut.
Remove the 2 bolts that hold the upper and the 2 bolts that hold the lower A arm to the hub assembly.
Once the bolts have been removed pull the metal bushing out about 1/4" to clear the hub. Remove the hub.
Suspend the drive shaft and slide the cv boot back towards the transmission so the cv can be seen. Carefully clean the grease off from where the shaft enters the cv, there is a snap ring there and it needs to be spread to remove the cv.
Now that the cv is off make sure it is clean and well lubricated. It is time to remove the old boot and install the new one.
Reverse the order to assemble.
Old Oct 8, 2003 | 11:42 PM
twoee96's Avatar
Default cv boot??
Thanks for your help. I got it fixed, it wasn't as hard as it looked. Now that I know how to do it, it will go faster next time. Thanks again,
Twoee96
Old Dec 19, 2003 | 08:38 PM
VSchlitz's Avatar
Default cv boot??
My inner cv boot ripped on my 2003 SP700 also. So I ordered the really good Gorilla boots, and doing allot of reading. I am pretty sure I will have to clean the joint, can I use my parts washer to clean the joint?
Old Dec 19, 2003 | 08:55 PM
pest44's Avatar
Default cv boot??
Yes.
Old Dec 20, 2003 | 10:38 PM
VSchlitz's Avatar
Default cv boot??
After the parts washer, I will dry the hell out of it. Then slide the new boots onto the shafts, slide the shafts into the CV joint.
Now is this were you pack the hell out of it with the grease? I guess you just push the grease into all the creavis's.
Old Dec 21, 2003 | 12:54 AM
Traildog's Avatar
Default cv boot??
Once you have the CV cleaned you can pack it with grease. Only use the amount supplied in the kit as it's not a good idea to over pack the CV. As you pack the grease in make sure you rotate the joint to it's extreme so you can pack grease deep into the joint. When finished the CV joint should rotate freely. At this time you can install the CV slip on the new boot.
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
cornermike
Sep 10, 2015 08:30 AM
