Countr blance oil
Old Oct 7, 2003 | 08:30 PM
savage21's Avatar
Default Countr blance oil
what kinda of counter blance oil do i put in and what esle should i check and change while i' have her down
Old Oct 7, 2003 | 08:37 PM
duneaholic's Avatar
Use a 10w-30 motor oil (70cc's) or around 3oz. The last time I changed it I used Mobil 1 10w-30. What do you mean when you say have her down? How old is your machine? How long have you had it?
Old Oct 7, 2003 | 08:56 PM
savage21's Avatar
I have a Scrambler 400 4x4 i have had it for a month or so going on 2 months, When i say i have her down i'm meaning i have her down for chain adjustments,lube job,wd-40everything,change plug,and just check everything over, i do this perdy much ever big hard ride,which is every week
but this time i had to install a new cv joint and boot kit, b/c i blew a cv joint, and i'm change hub oil
And my question what esle should i look at or do,
I have one more question i guess theirs know way to adjust the front shocks,right?
Old Oct 7, 2003 | 09:15 PM
BigBadScrambler's Avatar
Nope, no front shock adjustment. I would also pull off the skid plate and clean under there too. Also drain the starter and recoil housing, if you did any puddle hopping.
Old Oct 11, 2003 | 10:46 PM
BT250racer's Avatar
wheres the place to drain the starter and recoil housing??
Old Oct 12, 2003 | 01:39 AM
Its under the skid plate. There is a recoil drain plug, starter drain plug, and a counterbalancde drain plug on the 400's and just a recoil/starter drain plug and a crankcase drain plug on the 500's
