Scrambler 500 oil pressure and temp gauges
Has anyone put any gauges on their scrambler 500 and if so what type and brand did you use,and were do you put the sending units? I was thinking of geting a oil pressure and temp gauge but i am not sure on what type to get and if there is a place for the sending units...
thanks
thanks
Ive been thinking of doing that as a winter project. Autozone has the Sunpro gauges that have an oil temp, water temp, and volt meter i a 3 pack. The hard part would be figureing out where to mount them. I am not sure how thay would hold up to the abuse that I put my machine through though
I installed high lifters water temp. gauge. It was easy to install and it works and looks great. I made a bracket out of aluminum and mounted it between and just above the headlights.
'02 Scrambler-X 500 2x4, dg excellerator stage III exhaust system, heelclicker
clutch kit, aaen roller secondary, hpd steering stabilizer-airbox mod and jet kit,
hsp chain roller-alu. bar clamp-alu.dashplate-red shift ****, o'neal alu. bars,
smith grips, radlites, supercooler, h/l water temp gauge, sunstar 38t rear
sprocket, rear skidplate, fuel gauge, rear rack and ball hitch, 12v outlet,
flame decals, k&n filter w/outerwears, shock covers.
exmotocrosser
09-13-2019 06:12 AM
