I need some quad mechanic advice! help
Old Dec 11, 2003 | 11:54 AM
quadracer18's Avatar
Default I need some quad mechanic advice! help
I was riding my scrambler 500 yesterday..Just to run it a while since its freezin here..well It ended up dying on me after 10 minutes...simple mistake...I ran out of gas...no biggy...I filled it back up with gas..and havent got it running since...I got it started once after filling it up and putting it on high choke...white smoke came out of the exhaust while it was running..but after about two minutes it died..and hasn't been alive since. I can't even get it to want to kick over....I need some help..I have good gas in it...I'm just wondering If the carb. might have dirt or something in it??? But I plan on working on it this weekend..and I could use some info. on what the hell might be wrong!! I need to get it up and running soon. I'm getting quad fever and want to ride! Help!
Old Dec 11, 2003 | 12:28 PM
Fixitmatt's Avatar
Sounds like dirt in the carb, check the pilot jet it is for starting . the one ting that I don't undersand is how you say it dosen't kick over.
What do you mean.IT dosen't start? Or the motor dosen't turn at all. Is the starter tunning the motor?
Old Dec 11, 2003 | 12:37 PM
tryintoohard's Avatar
check your spark plug and clean it off or buy a new one. I bet it will fire right up, you may have flooded it.
Old Dec 11, 2003 | 12:52 PM
Ya, the engine is turning..so its kicking over its just not wanting to fire up....ya I figured I would clean out the carb this weekend...I've drivin it pretty hard and it probably does need to be cleaned out.....And for the spark plug...Ya Its about time for me to change it..I'll check it out to make sure its getting spark to....Thanks for you guyses help!
Old Dec 11, 2003 | 12:55 PM
Pennyless's Avatar
Put a new spark plug in it first. It is a cheap easy test. Good Luck
Old Dec 11, 2003 | 06:35 PM
BigBadScrambler's Avatar
The scram takes a while to get it to start after you run it out of gas (or take the carb off). You may have to crank on it for a while. But is sounds like you flooded and or fouled your plug
Old Dec 11, 2003 | 11:18 PM
lslubecki's Avatar
I think it's flooded also. Same thing happened to my Scrammy. I let it sit overnight and the next day it started fine.
Steve
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Scottma518
Jul 10, 2015 12:42 AM
Sjrpp
Jul 5, 2015 09:04 PM
