How do you turn up the idle on the trailblazer?
There is 2 ways of doing this. there is a small boot up by the throttle that splits in 2. There is an adjustment up there. Or on the side of the carb there is a small **** that you can turn with your fingers. This also controlls the idle.
Its # 13 on this list--------->IDLE SCREW its on the side of the carb you see it in the pic!!!
Use the idle screw on the carb ONLY! If you raise the idle by shortening the throttle cable when you turn the handle bars, the engine will speed up enough to get you in trouble quickly in tight spots!!!
ranvette
Jul 12, 2015 06:34 AM
03, 2002, 2003, accelerator, adjust, adjustment, cable, idle, polaris, raise, setting, speed, trailblazer, turn, turning
