Idling a little to low
Old Dec 20, 2003 | 12:24 AM
SuperX's Avatar
Default Idling a little to low
well when I set there and let it idle it idles a little to low, almost sounds like it's gonna die...then you rev it dies down, let off, rev again and it shoots up, then you let off... it goes to normal idling (where it should be) then drops back down
hope I didn't confuse anyone here if I did Im sorry
Brandon
Old Dec 20, 2003 | 12:26 AM
Hozed's Avatar
confused me...
what do you ride?
Old Dec 20, 2003 | 12:38 AM
Polaris500HO4x4's Avatar
just adjust it to how you think it should be. i know what you mean
like when you give it throttle is boggs out then if you let off and give it throttle again it revs up
SuperX's Avatar
00 TB 250
lemme try this
I crank it up ride it around the house a couple times, let it idle it dies down (sounds like it's going to quit but it doesn't)
i rev it to get the RPM's up...boggs down kinda and sounds like it's going to quit..but again it doesn't
I rev it back up to get the RPM's back up, it idles back down normally, then goes low again..
it never does die, just idles low
Old Dec 20, 2003 | 12:40 AM
SuperX's Avatar
where do I adjust it at?
Sorry Im not sure on where the idling screw is because I aint never dealt with this before
Old Dec 20, 2003 | 12:07 PM
DaveMaxx's Avatar
Check this thread
Old Dec 20, 2003 | 12:47 PM
SuperX's Avatar
thanks dave that helped and I got 'er fixed [img]i/expressions/face-icon-small-smile.gif[/img]
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
