BOOYA!!!!!!!!!
Old Dec 28, 2003 | 08:45 PM
Hozed's Avatar
Default BOOYA!!!!!!!!!
na i have had no problems with it... and it gave wicked bottom end... i could take off in second real strong with just the pipe... i wasnt geared down yet...
thanks for info.. shortening the hose was an idea i had.. but i just didnt see why it worked like it did before.. and why it wouldnt work now..
ive already replaced the washers and seals in there..
Old Dec 28, 2003 | 08:46 PM
Sceiks's Avatar
The long hose was in effect pushing the flange away from the crankcase (as if you were to grab the metal part of the hose on the flange and pull outward)
Sceiks's Avatar
Ok good luck.
Old Dec 28, 2003 | 08:47 PM
Hozed's Avatar
Originally posted by: EAB
I second the photo thing. Can a copper washer/gasket be used?
sorry.. didnt realize you had posted this.. just saw the photo part....
another buddy suggested that.. but i was having a helluva time trying to find one the right size... i had also thot of just a rubber o-ring.. but thot it might melt..
Old Dec 28, 2003 | 08:54 PM
  #15
quadwrench's Avatar
Hozed,
I'm assuming the lines you are talking about are HERE
Have you tried replacing the washers/"gaskets"? A lot of times the banjo bolts will not pull the lines down on used washers. Most of the time when I rebuild the top end on the 425's/500's - (I know they're different engines than the Pred, but the same principal) - I automatically replace the washers on the oil lines to make sure they seal - but the425's/500's are aluminum - the Pred's may be copper? (which is more durable - I've never had a problem getting copper washers to seal)
If you have aluminum washers, you can get some copper washers from the local auto parts house and try them before any radical "modifications"??
Old Dec 28, 2003 | 08:58 PM
  #16
Hozed's Avatar
i appriciate the help.. but its the lines under the catagory "engine mounting"
i have new washers and seals already... i am stumped...
Old Dec 28, 2003 | 09:10 PM
  #17
quadwrench's Avatar
I was trying to figure out how the oil tank on the Pred tied into the engine - now I know - just look under engine mounting - duh! why didn't I think of looking there??
The EX's and Foreman's (please forgive the mention of another "make" in this discussion [img]i/expressions/face-icon-small-smile.gif[/img] ) use a similar set up to tie into the oil cooler and I've had to replace the O rings with Viton O rings (don't know if that is what Polaris uses - Viton's are usually brownish tan in color) to get them to seal
Might be worth a try to save cutting the hose?
Old Dec 28, 2003 | 09:56 PM
  #18
Hozed's Avatar
lol.. obviosly the oil lines would be under engine mounting.. doesnt every1 know that!!!! lol (i had a bitch of a time finding it too..)
ya i am gonna try to shorten the lines a lil...
and the o-rings are black..
thanks for all the help all... still wondering what i can use as a sealer if a cant get em to stop leaking the right way.
Old Dec 29, 2003 | 12:50 AM
  #19
fishslab's Avatar
Are the ends of the hoses flared? Do they go over any kind of nipple in the engine or do they just butt up against the washer and O ring? Do the washer and O ring slip over the end of the hose?
Old Dec 29, 2003 | 05:56 PM
  #20
Hozed's Avatar
the end of the metal oil line goes into the engine about half an inch.. then the o-ring and washer fit in there...
i suck at explainin stuff so i dont expect you to understand this...
but i thot of doubling up the o-rings.. cause 2 will fit in there (i think).. even tho there is supose to only be 1...
