4x4 on demand. Limited slip in Hi range, Lock in Low range.
Old Jun 26, 2000 | 02:41 AM
fourlix's Avatar
A limited slip differential can be Locked,
diss-ableing the differential function and locking the axles together.
Silly Later, Fourlix
Old Jun 26, 2000 | 09:33 AM
walexa's Avatar
Something's wrong with your bike. The hub shouldn't release until you're back on hardpack. If the bike were mine, I would check or replace the armature plate in each hub. The armature plate is a thin black washer with 3 little "ears" that protrude into the back of the locking mechanism. If one of those ears becomes damaged, the symptoms you're explaining can happen. The armature plate is very inexpensive(less than $3), and relatively easy to replace. If that's not the problem, then I don't know what is. I think that the magnet is either working or not--i.e., it doesn't work some of the time and kick back out intermittently. If you have further questions, let me know and I will try to help you.
Don't Be Silly Now
Old Jun 26, 2000 | 08:00 PM
snowshark's Avatar
fourlix,
in regards to your first post. If Polaris could pull that off then it would be a "true" 4wd system!
Maybe some off the Polaris engineers will read this post & give them some ideas!
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
