connecting rods
Old Jan 6, 2004 | 07:30 PM
TWEEKER's Avatar
Default connecting rods
does anyone know if the rod from a 250 is the same as a 300 these being two strokes
Old Jan 6, 2004 | 07:42 PM
Hozed's Avatar
polaris makes a 300 2-stroke...
or do you mean a 250 bored to a 300?
if bored out then yes they are the same.
Old Jan 6, 2004 | 10:42 PM
mudmaster250's Avatar
you can bore a 250 that far?
Old Jan 6, 2004 | 11:19 PM
quadwrench's Avatar
EPI shows all the 250's and 300's up to '99 being the same rod kit.
Wiseco shows the biggest 250 piston being a 2.00mm (0.080").
Taking the formula of:
[bore X bore X stroke X 0.0031416] / 4
250cc bore = 72mm (std), 74mm (2.00mm over)
250cc stroke = 60mm
72mm bore : [72 X 72 X 60 X 0.0031416] = 977.1633 then divide by 4 = 244.29cc's
74mm bore : [74 X 74 X 60 X 0.0031416] = 1032.2041 then divide by 4 = 258.05cc's
Gained a lot, did 'ya??[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 7, 2004 | 12:50 AM
RickRitter's Avatar
The connecting rod , the bearing , the thrust washers , and the pin are the same between a 250 and 300 two-stroke .
The main bearings (the ones the crankshaft spins on ) are different .
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
