97 scrambler 500 prob!
Old Jan 18, 2004 | 02:47 AM
TRLYFZ450's Avatar
Default 97 scrambler 500 prob!
I am working on a 97 scrambler 500 that wont start. I checked the spark and it is fine. It is a fuel problem I think.
so i took off the carb and cleaned it out. Still it wont start so i spray some gas in the carb and it started and ran a few seconds.
OK not getting gas. i bypassed the fuel pump so i know the carb has gas. still wont start unless i spray in gas. I held my hand over the intake side of the carb to choke it and it started but would not idle if i removed my hand. i could rev it up as long as i kept choking it with my hand. if i covered 90% of the opening of the carb it will idle and rev up. I also know that if you remove the air box cover it wont rev up but it will idle."Talk about detuned". The main jet is clean and so is the pilot. Did i mension this type of carb sucks! (Vacuum slide)
Any help will be appreciated Thanks Terry.
Old Jan 18, 2004 | 04:51 AM
BigBadScrambler's Avatar
Thats the part of the problem. The CV carb need the vaccumm in the airbox to open the slide. That is why it is not recommended to mod the airbox unless you recalibrate the carb
Old Jan 18, 2004 | 10:04 AM
ftwflh's Avatar
Check the valve clearance should be .006 on both this could cause that problem too but if it isnt they need ed checked any way.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 18, 2004 | 08:53 PM
TRLYFZ450's Avatar
Thanks for the help [img]i/expressions/face-icon-small-smile.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
BigCam
Sep 16, 2015 01:53 AM
