polaris belts
Old Jan 29, 2004 | 10:33 PM
traildogg's Avatar
Default polaris belts
hi there iv got a 2002 trailboss 325, does anyone know how to prevent the water from getting in to the belt and stalling my bike, every time i ride through water or make a big splash the bike boggs down and stalls is there any modification that can stop this from happening? is there any other riders that have made some mods to correct this problem, any help appreciated thanx
Old Jan 29, 2004 | 10:36 PM
Bradracer18's Avatar
The only way that I know is to completely seal the clutch case up, and make the hole in a higher place, ive seen people us shop vac tube to do this. They usually run it up by the tank, so it can go in water up to the seat. The only problem with that is the motor and gearcase will probably start leaking. Brad
Old Jan 29, 2004 | 10:39 PM
csamayfield55's Avatar
Sounds like you have a bad cover or gasket!! Take the belt cover off and check to make sure it is not broken and check the gasket real good. If you don't find any problems replace it and fill the whole cover with water from the opening on the top and see where water is leaking out of then you can fix it
Chris
Old Jan 30, 2004 | 12:12 AM
fishslab's Avatar
Are you sure this is a belt issue? Water in the belt housing should not stall the motor unless it's getting in the crank seal. This sounds like a carb vent or air intake problem.
Old Jan 30, 2004 | 12:15 AM
guess I didn't read that close enough
Chris
Old Jan 30, 2004 | 02:43 AM
traildogg's Avatar
you know now that i think of it the dealer had installed some aftermarket clutch springs,maybe they didnt seal the cover when placing it back on the bike, it never did this before.
Old Jan 30, 2004 | 12:46 PM
Traildog's Avatar
Sometimes when the cover is removed the gasket can pull away from it's groove and if the mechanic didn't notice it, will not seat properly when reassembled. When you check the gasket, check it closely as it doesn't take much to cause it to leak.
Most Polaris's handle deep water quite well if driven at reasonable speeds. If on the other hand you hit the water fast then water will enter the clutch cover vent filling the housing. My 01 Sportsman can handle water levels upto the racks as long as I take it easy (not creating a bow wave) but keeping the revs up. Finding the balance takes a little practice.
Old Jan 30, 2004 | 02:58 PM
700quadman's Avatar
Water in your belt housing won't cause the engine to bog down and die. wet belts silp and the bike will quit moving because power isn't getting to the wheels. bogging down could be caused by water in the intake.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
