how to tighten the chain
Old Jan 31, 2004 | 06:50 PM
blaster2003kdk's Avatar
Default how to tighten the chain
how do u tighten the chain on a trailblazer.
Old Jan 31, 2004 | 06:52 PM
Hozed's Avatar
loosen the bolts and spin the thingy...
lol.. cant remeber but i am 99.9% positvive its just like my pred.
Old Jan 31, 2004 | 06:54 PM
what bolts u talkin about.it aint my bike iam askin for my friend
is it only two bolts
Old Jan 31, 2004 | 06:55 PM
Hozed's Avatar
i really cant remeber.. i havent had my scrambler for quite some time now... some1 on here can help you more than i can.. but if its the way i think.. its VERY simple... maybe look in his owners manual.. that says how too.
Old Jan 31, 2004 | 06:57 PM
ok thanks
Old Jan 31, 2004 | 07:59 PM
radblazer400's Avatar
Loosen 2 bolts on the swingarm that clamp the bearing carrier and the 2 bolts that bolt the rear caliper on. You can use a 2-1/2" wrench on the carrier or use a pin punch through the hole in the sprocket hub and rock the quad to rotate the carrier (which is accentric) to tighten the chain. The chain should have 3/16" to 3/8" deflection. The 2 carrier bolts should be torqued to 30 ft. lbs and the caliper bolts to 10-12 ft lbs. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 31, 2004 | 08:42 PM
Trailblazinrider's Avatar
the manual might not say what to do, I got this pos 2000 polaris manual and it covers all the 2000 modles, but not in detail, infact it didnt say nething about the tb chain. Now, i dont know if its all manuals, but mine is that way. My dad and i broke 3 tools, dont remember what they were, because it was different. Hope this helps
Old Jan 31, 2004 | 08:58 PM
csamayfield55's Avatar
Make sure you loosten the caliper bolts also!!! I tried to do it without those and you can't
Chris
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
