14.1 head
Old Feb 1, 2004 | 03:07 PM
xxxracerxxx's Avatar
Default 14.1 head
the next mod i am getting is a head for my sport it says to run 104 octane fuel but what if i don't will i just not get all power from the mod and can the stock gear box hanndle that much compression
Old Feb 1, 2004 | 04:21 PM
POLARISFREAK's Avatar
Default 14.1 head
By gearbox, I'm assuming you mean transmission. I haven't heard of anyone having problems with the trans. I know several people who have the hpd full race mod and have run it for years with no trans. problems.
Old Feb 1, 2004 | 04:31 PM
modquad's Avatar
Default 14.1 head
The only trans probs I've heard of is if someone is running the race mod w/ 4x4. The HPD head has the O-ring seals for a more effecient heat transfer. Also, why not go to the 15.5:1 dome, for just ripping around, you can easily run Av gas....also, iif you get rid of that DG pipe, your quad will thank you w/ more speed. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 1, 2004 | 04:32 PM
Default 14.1 head
thanks about the gearbox i don't want to pay 600 big ones for a new like i did on my trailblazer
Old Feb 1, 2004 | 04:36 PM
Default 14.1 head
i looked for others but hpd and other polaris companys don't makw them for a 1994 i think it is to old fmf dose but they only make the gnarly pipe and i will loose top end do you know of anyother pipes
Old Feb 1, 2004 | 10:29 PM
badcompanyracing's Avatar
Default 14.1 head
did you try CPI?
Old Feb 1, 2004 | 11:42 PM
Default 14.1 head
dose it have a web site
Old Feb 2, 2004 | 01:13 AM
WileyCoyote's Avatar
Default 14.1 head
I definitely would not run regular gas with your 14:1 head. 91 octane fuel is too volatile, and will pre-ignite with such high compression. You'll be looking at severe engine damage. Stick with the recommended 104 octane.
And didn't you make an earlier post about removing the radiator fan? I take it this machine is just going to be a drag racer? If not, you might want to reconsider the removal of the fan.
Old Feb 2, 2004 | 03:33 PM
Default 14.1 head
well i might just get a pro design cool head with the interchangable domes during the racing season i will put in the 14.1 dome then when i trail ride i will put a 12.1 dome in
Old Feb 2, 2004 | 03:35 PM
Default 14.1 head
or i will buy 94 octane and put octane boost in it to make 104 and i was the one about the fan i may drag race
