Oil pump block off!
Old Feb 3, 2004 | 03:54 PM
DAVEY300's Avatar
Default Oil pump block off!
How does everybody feel about blocking off the injecter and using pre-mix oils?
Old Feb 3, 2004 | 04:02 PM
badazz400's Avatar
yea i think its a great idea. its a little more work premixing your oil, but its no big deal. at least you know your oils getting to your motor
ross:frown[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 3, 2004 | 04:23 PM
DAVEY300's Avatar
I installed a block off plate,I'm running Klotz synthetic oil . Ratio 40:1
96 300 express.Dyno port pipe .50 over Weisco K@N.Jet Kit. proflow port-polish
Old Feb 3, 2004 | 06:19 PM
xxxracerxxx's Avatar
i would use pre mix so you don't have to worry about the pump breaking and not putting any oil in the motor so it dosen't seize
Old Feb 3, 2004 | 07:55 PM
fishslab's Avatar
Personally, I'm not a fan of blocking off the injector. I have not heard of an injector on a Polaris ever failing. If you are a racer and trying to drop weight that is a whole different thing. When you premix you are locked into what ever ratio you mixed, so at idle it may be getting too much and at WOT it might not be getting enough. The injector gives it more oil as throttle position is increased thus oiling for demand. Plus I can just buy regular gas for all of my euipment and not have to worry about a mixed gas jug for this quad and one for that quad.
Old Feb 3, 2004 | 08:16 PM
ya i took mine off to drop weight but i think you are right that the polaris ones don't fail that much i never had a problem with mine when i had it
Old Feb 3, 2004 | 08:20 PM
tbsleeper's Avatar
is it worth it to lose it? i wanna take mine off but i dont like the sound of wat fishlab said.
Old Feb 3, 2004 | 08:33 PM
Polaris500HO4x4's Avatar
nah my buddy has an old 87 250 and its been in the pond at least 3 times the injector is still goin strong. but in my old honda moped i happened to be riding around the 5 mile block and it locked up on me, the injector got blocked and the engine burned up.
Old Feb 3, 2004 | 09:09 PM
2manytoys's Avatar
I agree 100% with fishslab. The Polaris injestors are very reliable. I have heard very few failures. And with as many 2 strokes that Polaris puts out if they had injector problems it already would have been addressed with Polaris. And for the weight savings it only weighs about a half pound. Is it really worth the hassle to save half pound? I think not! But yes it is a different story for racwers. They run half to WOT 90% percent of the time durring races. Thus it burns the oil off quicker. If you do alot of trailriding and you get to a strech of trail that you have to go slow then the likely of fouling a plug is much greater. Not what I want to deal with on the trail in the middle of having fun. But it is up to you. Everyone has thier opinion.
Old Feb 4, 2004 | 09:30 AM
bisho12's Avatar
I dont know about being reliable. I have a 99 sport 400. I bought it used. It smoked a lot when I got it in sept. o3. I checked the oil injector and when I took the cover off I found out that the cable from the throttle was broken off before the pump. So it was running at a certain mixture all the time. When I got the oil block off kit I was woried about mixing fuel and oil (first 2 stroke) but its not bad at all. Best part is it doesnt smoke now (except for 2 stroke normal smoke) and I know it is getting oil. It also has more power since the mixture was too rich with oil.
Check the belt too. I just put a new one on and she pulls like a S.O.B.
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
