Scrambler '04...while "unstucking" a buddy, it smokes and now makes a clickin noise...
Old Feb 8, 2004 | 10:40 PM
user3657's Avatar
Default Scrambler '04...while "unstucking" a buddy, it smokes and now makes a clickin noise...
ok here is what happen.......I was trying to pull a buddy out and i gave mine some gas and it made a big cloud of smoke. I wasnt aware of this cuz i was looking back to see if i was moving my friend while the other guys were yelling STOP STOP and i couldnt hear them. now it makes a clicking nosie when you drive it....the noise comes from the left side if you are sitting down on it.....
It is only 3 weeks old and I hope the warrntey covers it but does anyone have any idea what could of happen?
thanks
Old Feb 8, 2004 | 10:43 PM
DGpolaris2346's Avatar
Did you smell burnt rubber? It could be the belt
Old Feb 8, 2004 | 10:44 PM
user3657's Avatar
yes there was a smell too it..........but if I burnt the belt it would make a clickin noise like that?
Old Feb 8, 2004 | 10:48 PM
Maybe thats just your chain clickin against the chain slider because mine used to click untill i tightened the chain a little bit but i think its your belt. Pull the PVT cover off and check the belt.
Old Feb 8, 2004 | 10:51 PM
scrambo's Avatar
Yes! absolutely would... You can check the belt very easily, just take the clutch cover off and look at it. The clutch cover is the big black bulky plastic cover on the left side of the bike located at your left foot. Just remove the screws and strap on the vent tube and it should come off easily.
Old Feb 8, 2004 | 10:55 PM
user3657's Avatar
no its not the chain it does it at low speed I had to drive slow as hell back to the trailer because of it. I am hoping it is just the belt....but they said its wear and tear and isnt covered......maybe cuz its like 3 weeks old I can see what they can do.
Old Feb 8, 2004 | 10:58 PM
yea pull the clutch cover off and check the belt i bet it is your belt. not a big deal really.
Old Feb 8, 2004 | 11:41 PM
Quadfather's Avatar
You wore a groove in your belt from the clutch spinning, but the belt did not. Now, every time the belt makes a revolution, it thumps, or clunks when the groove goes around the clutch pulley.
Old Feb 9, 2004 | 01:19 AM
TreeDoc's Avatar
Hey, Polaris has a limited lifetime warranty on their belts....at least my Sportsman does. Dealer said the first, second, and third are "on them" after that, you're blowin' it....buy your own!
Old Feb 9, 2004 | 09:50 AM
WJW's Avatar
WJW
But like all warranties it dose not cover abuse I think you will by buying a belt.
