help
Old Feb 14, 2004 | 08:30 PM
markbanger's Avatar
Default help
thanks i'll try that. but if i can get to that bolt with out taking off the airbox and stuff will that work.
Old Feb 14, 2004 | 09:59 PM
Jayblazer's Avatar
Default help
yes
Old Feb 14, 2004 | 10:13 PM
markbanger's Avatar
Default help
which jet should I use, 2 came in the same bag. the bag says main, jet Lg round #147.5 what ever that means. When you look at them closely there is one that is 140 and the other is 147.5. which should I use and should i ever switch them.( like in the summer)
Old Feb 14, 2004 | 10:38 PM
Jayblazer's Avatar
Default help
i think that they send them specific to your region If they dont they should but since it is winter i would go with the 147.5 and see how it runs do the plug test and see if your to rich/lean and go from there you
may want to start a specific thread about people who are about the same elevation and temp as you and see what they are running i dont want to steer you wrong im more of a 2 stroke guy but it seams that the larger jet would work...
Old Feb 15, 2004 | 12:18 PM
  #15
markbanger's Avatar
Default help
how do you get the old jet off. I screw driver doesn't work and no socket will fit it.
Old Feb 16, 2004 | 02:12 AM
  #16
JEFF10049's Avatar
Default help
well my friends was a flat blade screwdriver what does the new one look like? also there may be a washer under the jet so watch for that. the jetting has to be really close on those constant velocity carbs for a good throttle response so don't get disscouraged if it don't work good the first time. a 137.5 worked good on my friends quad at 3500' elevation.
hope this helps
Jeff
Old Feb 16, 2004 | 02:15 AM
  #17
JEFF10049's Avatar
Default help
forget about the 137.5 jet that was with a hsp pipe I did not see you had a wb sorry.
Jeff
