Tires Question
Old Feb 14, 2004 | 12:54 AM
Polaris500HO4x4's Avatar
Default Tires Question
i was just wondering if your atv has a stock tire of 25 and you put on a 26 inch(450cc by the way) will your atv get slowed down by the larger tire of will it increase the top speed?? i already no that it will loose a little bit of the power but that doesnt matter.
Old Feb 14, 2004 | 12:57 AM
Christopher325's Avatar
ok... my thinkin would be... you would accel as fast but in a straight stretch you would increase top speed... but it wouldnt be a very big diff... so if you want 26... then no harm done... except to who evers check book your using...
Old Feb 14, 2004 | 01:29 AM
BT250racer's Avatar
it would slow down your accel and pick up your top speed some but not enough for either of them for you to notice.
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
Old Feb 14, 2004 | 02:02 AM
Disturbed_81's Avatar
Yeah it would knock the Acceleration down and increase the top speed a little bit .. add a tooth to the rear sprocket and it would probably even it out a bit.
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
Ean
Aug 28, 2015 09:39 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
