BIG thumping noise
Old Feb 22, 2004 | 02:48 PM
tbsleeper's Avatar
Default BIG thumping noise
ya because when the sprocket comes to that location at a slow speed it grinds over it and doesnt connect. my whole quad would shake and make a big noise when it hit that area on the chain but wouldnt make a noise at high speeds. the guy that fixed it at the dealer said to never use wd-40 on chains because it wrecks the o-rings
Old Feb 22, 2004 | 03:23 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
chain slap on the swingarm (usually only from a kinked link, causing it to protrude lower than the rest of the chain)
Old Feb 22, 2004 | 03:34 PM
Sparkie's Avatar
This sounds daft but I had a noise the same as you describe and found it to be that I had over tightened the chain. Well I didn't exactly over tighten it but found that the swing arm bushings had worn and this gave some front to back movement. This meant that when I tightened the chain in the garage the swing arm was at it's most forward point. When I went out the swing arm would drop back which in turn over tightened the chain. It then snapped after getting a little air.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
