What to look for when buying used (2 Stroke)?
Old Mar 5, 2004 | 09:24 AM
pullthetrigger's Avatar
Default What to look for when buying used (2 Stroke)?
I am looking at a 2000 xplorer tomorrow. I was wanting to know what to look for when buying a used 2 stroke. I am not going to be able to take the quad to a shop to test compression, but what can I look for and listen for that will tell me how good a shape the motor is in? It is an Xplorer 400. I like this engine, I used to have a scram 400 and it is the same engine.
Thanks
Old Mar 5, 2004 | 12:07 PM
CED's Avatar
CED
Make sure you check the counterbalancer,pull the dipstick.
Old Mar 5, 2004 | 06:06 PM
tbsleeper's Avatar
make sure the guy lets you take it for a ride and if he does pin the gas a few times and if it runs good buy it.
Old Mar 5, 2004 | 07:26 PM
Bubba297's Avatar
I would see if the stock piston has been replaced or not. If it hasnt then a rebuild will be in store not too far down the road or else your setting on a time bomb with the stock 400 piston. If it has, then a slight bit of piston rattle or noise will be normal with the wiseco due to increased tolerance.It is the same motor as the scammy had. Good luck,Bubba
Old Mar 5, 2004 | 09:29 PM
Jayblazer's Avatar
if the stock piston blowes does that mean that the quad is totaled????
or does it just mean that its time to find a wiscoe
im with ced on the counterbalance thing i looked at 2 before i bought mine and all 3 had leaking counterbalances
Old Mar 6, 2004 | 09:34 AM
CED's Avatar
CED
No the quad will not be totaled.What happens is the skirt will crack then eventually break off and guess where the pieces go,yep into the bottom.So it is very good insurance to replace the stock one with a new one.
Tomtom86
Aug 7, 2024 07:40 PM
Cummins Driver
Sep 11, 2019 01:22 PM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
