What would happen If I....
Removing disks will reduce sound output and help the bottom end.
Adding disks will increase sound output and help the top end.
Adding more disks than the max your pipe is set up for won't make any difference (if your pipe has room for a max of 12disks then putting 16 disks won't make any difference)
You may have to rejet if you go to the extreme on either way
Sw00p
09-24-2015 02:50 PM
Elkaholic
09-06-2015 02:44 PM
