front fenders on pred
Old Mar 15, 2004 | 06:04 PM
Bradracer18's Avatar
Default front fenders on pred
Hey guys, I'm sure that I'm just not seeing how to do it, but how do you remove the front fenders on the pred? Does the black nose piece come off? I removed all of the obvious bolts, but the two near the handle bars won't come loose, and the bolt is twisting, if I could get the black piece off I think I could get to it. I am trying to install my tether cord. I don't see how the black piece comes off. Thanks Brad
Old Mar 15, 2004 | 06:23 PM
Superballs5337's Avatar
u could use tin snips, a torch, a saw, fire. but then thats not a good idea. good luck man.
Old Mar 15, 2004 | 06:28 PM
badazzpred's Avatar
the front fender cab piece comes off in one unit, disconnect the headlamps, then 3 bolts one right in the center above the black nose piece theres an air opening look in farther you will see it. Then 1 bolt on each side mounted to the frame. then pull the whole unit towards you slides right off. Takes about 3 minutes, hope this helps ya.
Old Mar 15, 2004 | 06:39 PM
fidge1's Avatar
It is a pain in the rear. You have to take the nose piece of first and then the headlights and all three frame mounts, then the mount near the stem has a bolt also. Then there are 2 clips on the gas tank that you have to pull out... Good luck-- I broke my nose piece while doing mine
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
carolinabomb
Jul 26, 2015 08:40 AM
cSchwartz
Jul 10, 2015 08:06 PM
