2004 TRAILBLAZER LE WHEELS/TIRES
Old Mar 21, 2004 | 10:42 PM
Mister's Avatar
Default 2004 TRAILBLAZER LE WHEELS/TIRES
The tires on our new trailblazer LE lose most of the air pressure in a weeks time. It has the Douglas aluminum wheels which come standard on it. It has been doing this since we got it and I thought it was due to the extreme cold temps earlier this winter but is still doing it. Anyone else having this problem with the LE? Thanks.....
Old Mar 21, 2004 | 10:50 PM
BigPolarisDog's Avatar
We got a 2004 Trailblazer in Jan. and have had some problems with that but not to the extent it sounds like
you have had. Ours isn't an LE and just the plain white steel rims.
Old Mar 22, 2004 | 12:36 AM
BigBadScrambler's Avatar
Sounds like a slow bead leak. Easy test, fill the tires up with a lot of air. Take them off and submerge them in a tank of water. That will show you where the leak is coming from
Old Mar 22, 2004 | 12:45 AM
mistertinker's Avatar
take wheels off. air them up to correct pressure. get soapy water put around rim at bead. if it bubbles break bead loose put rtv silicone on bead and air back up. no more leaks. i had same problem on brand new trailblazer 250 2003.
Old Mar 22, 2004 | 12:47 AM
Needmoretoys's Avatar
Hello,
I haven't had any trouble with air leaks on my Trail Blazer 250 LE..
03 Trail Blazer 400, Black
04 Trail Blazer 250, Red LE
03 Trail Blazer 250, Was Blue LE, Now Freedom Scheme
03 Trail Blazer 250, Yellow
02 Scrambler X 400 4x4, Blue LE
95 Explorer 400 4x4, Red
92 Trail Boss 250, Gray/Blue
85 Odyssey 350
86 Dune Buggy
03 Pioneer
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
chewy78
Sep 8, 2015 10:37 AM
