Could someone point out the Rev Limiter in these Pics?
Old Mar 29, 2004 | 04:57 PM
Stainless's Avatar
Default Could someone point out the Rev Limiter in these Pics?
Bought a 1995 Polaris 250 Trailboss a little over a week ago and now that I added a good battery the quad dies when I throw it in reverse. I unhooked the wires off of what I'm guessing is the reverse indicator switch in the transmission and it runs fine but wont light up the R light. A few other guys on here told me to unhook the black wire off of the rev limiter and that will fix the problem. I took a few pics and was hoping that maybe someone could point out where the wire is that I need to cut or unhook. Here is the link:
http://69.64.34.181/Pic_Page.htm
Old Mar 29, 2004 | 05:34 PM
Bradracer18's Avatar
The rev limited probably doesn't have anything to do with it if you take the reverse indicator off and it runs fine...that to me says the problem is right there..you must be grounding out in the indicator somewhere.
Old Mar 29, 2004 | 08:26 PM
csamayfield55's Avatar
I think that pic is of the rectifier for the charging system but I could be wrong. try looking in partsland.com
Chris
Old Mar 29, 2004 | 11:27 PM
quadwrench's Avatar
Reverse limiter should have 4 wires - black, green, white, and yellow
The voltage regulator should have 3 wires - yellow, red, yellow/red stripe
Old Mar 30, 2004 | 10:15 AM
Stainless's Avatar
Thanks Quadwrench.
Customer Service #1
May 15, 2020 08:46 AM
bigred20653
Oct 2, 2015 10:05 AM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
