Caution 04 500 ho owners.......
Old Apr 19, 2004 | 07:28 PM
ftwflh's Avatar
Default Caution 04 500 ho owners.......
Originally posted by: 71stang99
I had one issue so far with my scrambler, on the first ride on the scrambler I had the stearing bolt nut fall off on the first ride, the quad still rode but it was a damper since it was the first ride, cheap fix and Ive been out twice since without any problems. Anyone deal with the dynojet kit for the 4x4 scrambler? I just received mine off of ebay and I will order my pipe probably this week. I want to order the HPD, is the 300 dollar price tag right?
Thanks
On the HPD pipe I personally didnt see the $$$$$ in it.I went with a WB Eserries for around $175 and got great results with just a K&N and no jetting.Aaens muffler with sparkarrestor was around $240.On the jet kit it will be harder to get the carb off than to put the kit in and just HOPE you get it right the first time.Good Luck on your kit.
Old Apr 20, 2004 | 12:36 AM
nez02's Avatar
MOUNTAINEERRIDER
I bought my scrambler from bairs a year ago. What do you think about them?
Nez
Old Apr 20, 2004 | 08:44 AM
Snowride's Avatar
today while i'm pounding up a knarly hill my throttle sticks whoa.......nelly!
You may want to have them check the ETC function. A stuck throttle cable will basically kill the engine power if it is stuck when let off the throttle. By the sounds of your post, it sound like you got lots of power happening.
Old Apr 20, 2004 | 09:24 PM
MOUNTAINEERRIDER's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]NEZ02..I have been dealing with Bair's since 1991..no problems..Great dealer ...My family has bought aound 30 atv's and yet to have a problem with their service... GOOD PEOPLE ...SUPER SERVICE!!!!
Old Apr 21, 2004 | 09:01 AM
  #15
1995400's Avatar
I took a few minutes last night to look at my cable, it was late and I couldn't see very good. I didn't see any chaffing or feel any worn places, I plan to look a little closer this weekend. A small hose would probably be a cheap fix if there is going to be a problem. Thanks for the heads up.
Old Apr 21, 2004 | 09:44 AM
  #16
Bytor's Avatar
Just need a clarification. I checked my 04 SP400 and didn't notice the cable near the shifter bracket (didn't pull the panel off yet). Is this a problem with the 04.5 Sportsmans with the in-line shifter or the 04 with the H-pattern shifter, or both? Thanks.
Old Apr 21, 2004 | 10:31 AM
  #17
20045SP500HO's Avatar
It looks like all sportsmans with inline shifter ... just take off the right side (shifter side) panel and starting at the carb ... following the cable with your hand ... about 4" before the carb (toward the front of the machine) there is a cross member ... the cable is rubbing on this metal cross memeber. You should be able to lift the cable and see the paint is rubbed off the cross memeber and the cable is worn.
Old Apr 25, 2004 | 07:53 PM
  #18
********UPDATE
When riding for the first time after getting my 500HO back with new cable and routing ... now stalls @ idle when you place the sterring full right or left. Taking it back to dealer on monday so they and Polaris can look into the problem. Looks like the new mounting points are causing the cable to not flex correctly and hold a steady idle under hard left/right sterring.
Old Apr 25, 2004 | 08:50 PM
  #19
Snowride's Avatar
Just back off a hair on the ETC adjusment and the issue will be history.
Old Apr 25, 2004 | 10:38 PM
  #20
tried that ... no luck, made it real loose ... must be something else.
bamaquad06
Aug 3, 2008 04:51 PM
AAMCOKurt
Jan 8, 2007 01:29 PM
out4elk
Feb 22, 2006 07:14 PM
reconranger
Nov 22, 2005 10:30 AM
