Caution for UNI Filter Users
Old Oct 30, 2005 | 11:20 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Caution for UNI Filter Users
UNI filters come with a wire insert that supports the filter. The insert has a plastic collar, where it fits into the air intake boot. You need to inspect these collars each time you clean your filter! Over time, the plastic collar on the insert may compress from the pressure of the metal band that holds the filter in place, and will begin to take on a taper and will eventually no longer fit tightly into the intake. At this point, it needs to be replaced.
Another caution, at the time this was written the UNI catalog appears to have a lot of errors!
On my 400EX and 450R, my collars have compressed over a period of a little over a year or so. The collars ended up looking tapered (but like they were manufactured that way), rather than being square. It fooled me for a while, and if you like you can read the whole convoluted story here........ http://forums.atvconnection.com/mess...did/471223.cfm
Old Nov 22, 2005 | 10:12 AM
Red Rider
My solution, at least for the 400EX and 450R.
http://forums.atvconnection.com/mess...TARTPAGE/1.cfm
Old Nov 22, 2005 | 10:30 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Thanks for the tip recon. I had a tear on mine before, but that was after about two years of use so it was time for replacement anyways.
bmxatv10
Oct 14, 2022 06:23 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
tysonbully
Sep 28, 2015 02:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
black798
Sep 9, 2015 07:42 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
