Brakes For 2000 Trail Boss
Old Apr 12, 2004 | 09:40 PM
SS2's Avatar
SS2
Default Brakes For 2000 Trail Boss
I just wanted to know how hard it is to replace the front and back brakes on this ATV?
SS2
Old Apr 12, 2004 | 11:35 PM
scootergptx's Avatar
Supersock
Hired Gun!
It's pretty easy. Take off the caliper mounting bolts and lift off the caliper. Push the caliper piston into caliper bore (slowly, with old pads still in place). Remove the pad retaining pin and spacer. Remove old pads, replace with new. Be sure to put aluminum spacer between the pads. Install the caliper and torque to 18 ft lbs. pump brakes, bleed if necessary. You can take off the rear wheel if you need more room.
Sorry that was just the back brakes.
Front brakes, remove wheel. Loosen pad adjuster 2-3 turns. Remove caliper from mounting bracket. Push caliper piston into caliper bore. Push mounting bracket inward and slip outer brake pad past edge. Remove inner pad. Reverse for intstallation.
Not much different than a car.
greg74
Sep 10, 2019 03:03 PM
bafisher1986
Jul 21, 2015 04:12 PM
Gnuters
Jul 19, 2015 10:03 AM
timster911
Jul 13, 2015 01:57 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
