Chain Woes
Old Apr 16, 2004 | 07:56 PM
scrambo's Avatar
Default Chain Woes
fishslab is correct...usually you do have to loosen the caliper bolts also in order to free up the axle housing. mine turned pretty easily once I loosened all four bolts. I bought a very large pair of channel lock pliers just for this purpose. Also, if your behind the machine put the pliers on the housing once you've loosened all four bolts and twist up to tighten the chain. If you twist down you'll most likely loosen the chain even more. I learned that part the hard way. LOL!!!
Old Apr 16, 2004 | 08:47 PM
DGScrambler400's Avatar
Default Chain Woes
ok thanks, ill check my caliper, it must be loose[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 16, 2004 | 09:09 PM
thewayout420's Avatar
Default Chain Woes
you need to put a small phillips screwdriver through the sprocket hub and into the axle housing,the hole in the axle housing is lined up with the grease zerk.once all 4 bolts are loose and the screwdriver is slide into the housing roll the machine forward or backward to get the chain set where you need it..
Old Apr 17, 2004 | 05:40 PM
Default Chain Woes
i went out and looked at it today, and everything was tight. After i thought about it, i remember that i had to loosen more than just the swingarm, i had to loosen the caliper also... thanks for the help though[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 17, 2004 | 05:41 PM
  #15
Default Chain Woes
i feel stupid now..[img]i/expressions/face-icon-small-blush.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
salixair
Nov 3, 2015 08:25 AM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
