Gas milage ?
Old Apr 23, 2004 | 10:05 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default Gas milage ?
Replace your airfilter and clean the outerwear.
Old Apr 23, 2004 | 02:20 PM
BigBadScrambler's Avatar
I agree. A dirty air filter can cause a lot of issues that may seem more serious than they are. You cant clean the stock filter. Your best bet would be to pick up a K&N. You can clean that as much as you need to. Its the last filter you will every need to buy
Old Apr 23, 2004 | 07:00 PM
rsking45's Avatar
My sp is the early model 500,wish that I knew about the 04.5 at the time that i bought this one, so it has a 5.25 gal tank.While looking at it today I noticed that the exaust seamed to be a little black,so I am going to clean the air filter check the plug,try some carb cleaner.If i buy a kn filter will I have to rejet?
Old Apr 23, 2004 | 09:07 PM
ftwflh's Avatar
Want to talk gas milage?Try my 400 Sportsman dont have a speedo anymore but when I get more the 10 miles from my truck I take a spare gas can. Now my Scrammy seems to go forever.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 24, 2004 | 01:06 AM
  #15
No need to rejet for the K&N
Old Jan 7, 2005 | 08:12 PM
  #16
Bloombastic's Avatar
I went on a 40 mile ride today with the ground covered in ice and snow. I had alot of spinning and was in 4x4 the hole time. when I went to the pumps, I topped it off with 2 gallons. I don't think this is too bad considering the machine is new and has less than 40 hours on it. By the way, I ride a SP700EFI. C-Ya
Old Jan 7, 2005 | 09:55 PM
  #17
20045SP500HO's Avatar
I get around 60 miles on the tank full, but when riding mud / rock climbing i've got only 20 miles on a tank ... but thats alot of spinning, tipping, and idleing.
Old Jan 7, 2005 | 10:38 PM
  #18
Primus's Avatar
I went on a ride in the summer with my stock 2004.5 SP500H.O. on gravel logging roads doing a constant 50 to 55 MPH and got 65 miles when the low fuel warning lit on the display. That was in 2 wheel drive, high range with about 25 to 30 hours on it.
Old Jan 7, 2005 | 11:43 PM
  #19
MaineMudder3's Avatar
I ride hard with aftermarket exhaust,jet kit and air filter. Plus my clutching set up makes the motor rev about 400 rpms higher then stock. I get about 75 miles to a tank.
Old Jan 8, 2005 | 12:05 AM
  #20
crblick's Avatar
Running rich will effect your gas milage(use more fuel). Take a look at your sparkplug and see if it's a dark color. If it is, lean your carb out till the plug becomes a tan color.
